Showing results 1 to 7 of 7
Thread: Auto export of CEL mix up events in export files...
    22.03.2013
    5
    Default Auto export of CEL mix up events in export files...
    Hello all
    I want to export a CEL every day at midnight containing the events of the day in a file where the name states the date.
    I have a Zenon 6 6.51, where i have defined a Timecontrol "cyclic from that day" at 23:59:00, it calls a build in function "Export CEL"
    Export CEL is set up to export with the date as filename and "Set tilter at time filter type" and "Relative period of time" set to 1 day.
    The problem is that sometimes, stores events from the day before in a file. What is set wrong here?
    Kindly regards
    Default Re: Auto export of CEL mix up events in export files...
    Hi ttj,
    Thanks for your post, and welcome to the forum
    Do you have an idea under which circumstances events from the previous day are included in the export file?
    What file date (file properties in Windows explorer) does the export file have?
    How many events from the previous day (roughly how much time) are included?
    In theory with these settings 1 minute of the previous day could be included (23:59:00)
    22.03.2013
    5
    Hello markclemens
    Thank you for your answer.
    You can see an example from an actual file. I had to cover some names by xxxxxx.
    Filename c130831.txt ( that means 31/8-2013 )
    30-08-2013 23:41:45.100;xxxxxxxxxxxx xxxxxxxxxxxx NON URGENT ALARM ;COME;1;
    31-08-2013 10:40:03.833;xxxxxxxxxxxx B IS ACTIVE;GO;0;
    31-08-2013 10:40:03.836;xxxxxxxxxxxx B IS ACTIVE;COME;1;
    31-08-2013 10:47:08.326;;xxxxxxxxxxxx checked in.;;
    31-08-2013 10:56:28.546;;Authorization on new computer;;
    31-08-2013 10:57:11.990;;System was stopped;;
    31-08-2013 10:57:13.037;;xxxxxxxxxxxx' checked out.;;
    31-08-2013 17:55:35.657;;xxxxxxxxxxxx' checked in.;;
    31-08-2013 17:57:11.803;;System was stopped;;
    31-08-2013 17:57:11.846;;xxxxxxxxxxxx' checked out.;;
    31-08-2013 19:15:01.189;;Authorization on new computer;;
    31-08-2013 19:17:41.028;xxxxxxxxxxxx A FAULT;COME;1;
    31-08-2013 19:17:51.252;xxxxxxxxxxxx A FAULT;GO;0;
    31-08-2013 19:17:57.736;xxxxxxxxxxxx A FAULT;COME;1;
    31-08-2013 19:17:59.564;xxxxxxxxxxxx A FAULT;GO;0;
    31-08-2013 19:18:05.583;xxxxxxxxxxxx A FAULT;COME;1;
    31-08-2013 19:18:07.450;xxxxxxxxxxxx A FAULT;GO;0;
    31-08-2013 19:19:05.527;xxxxxxxxxxxx A FAULT;COME;1;
    31-08-2013 19:19:07.344;xxxxxxxxxxxx A FAULT;GO;0;
    31-08-2013 22:08:49.990;xxxxxxxxxxxx;COME;1;
    31-08-2013 22:08:50.020;xxxxxxxxxxxx;COME;1;
    31-08-2013 22:08:51.438;xxxxxxxxxxxx;GO;0;
    31-08-2013 22:08:51.520;xxxxxxxxxxxx;GO;0;
    31-08-2013 22:19:10.190;xxxxxxxxxxxx;COME;1;
    31-08-2013 22:19:10.220;xxxxxxxxxxxx;COME;1;
    31-08-2013 22:19:11.436;xxxxxxxxxxxx;GO;0;
    31-08-2013 22:19:11.520;xxxxxxxxxxxx;GO;0;
    Please note event with timetag:
    Sometimes i have more from the day before
    Kindly regards
    Hi ttj,
    What are the different timestamps of the file "c130831.txt" when you look in Windows Explorer in the file properties?
    What timezone is the PC that runs the runtime on, set to? Is the PC with the editor in the same timezone?
    22.03.2013
    5
    Hi ttj,
    Hello Mark
    c130830.txt
    was created ‎30. ‎august ‎2013, ‏‎23:15:01
    c130831.txt
    was created 31. ‎august ‎2013, ‏‎23:14:01
    There are two redudant HMI's, they are timesynced via a NTP. The editor is running on one of the HMI's.
    Kindly regards
    Thomas
    Hi Thomas,
    My guess based on the timestamp is that every day the function is executed 1 minute earlier, and your cycle time is also 23hours and 59 minutes.
    A cyclic function executed every 23hours and 59 minutes, would be executed at 23:15 after about 45 days.
    When you use "from that day" at the time control function, tick all days for the execution days, and specify midnight for the execution time, it should work without the function being executed 1 minute earlier.
    22.03.2013
    5
    Thankyou Mark
    I will try to do the settings!
    Kindly regards
    Thomas
  1. Historian import and export
    By natasjagts in forum zenon Supervisor
    Last Post: 23rd May 2012, 13:36
  2. Export CEL to SQL
    By skywalker in forum zenon Supervisor
    Last Post: 14th September 2010, 12:24
  3. is there a way to change the export path in the RT(CEL
    Last Post: 10th December 2009, 19:20
  4. Datentyp export
    By lunzer in forum zenon Supervisor
    Last Post: 30th November 2009, 02:09
  5. Cumulative export of alarms.
    By nsko in forum zenon Supervisor
    Last Post: 4th September 2008, 12:38
