Thread: Screen Name identification in Double Monitors
    Default Screen Name identification in Double Monitors
    Hello Gents,
    First Question:
    I have a double monitor project, i am opening same screens and frames in the startup so two monitors are clones and after project start it gives me flexibility of having different screens.
    I am getting the picture name from my "frame_workspace" and using it for renaming my pdf printouts. However it is working just for first monitor! Even i call the function in second monitor it is always returning the name of picture in first monitor not second.
    Second Question:
    For coloring screen switch buttons (screen menus) --to see which picture is open-- i was using system active variables(with internal variables). However now i have two identical monitors, so i cannot show which screen is open in which monitor. Do you have any ideas about a new method?
    Any ideas?
    Default Re: Screen Name identification in Double Monitors
    I'm not sure about your first question. Have you looked at the property "MonitorId" and "Online" ?
  1. Replies: 7
    Last Post: 15th January 2014, 10:48
  2. Close one screen, opens other screen
    By dario in forum zenon Service Engine Supervisor
    Last Post: 14th November 2012, 10:34
  3. variable Identification
    Last Post: 13th September 2012, 00:31
  4. vba Double Command?
    By eyup in forum VBA
    Last Post: 13th August 2009, 23:59
