Thread: Problem with Web Server on zenOn 7.10
    28.07.2010
    16
    Default Problem with Web Server on zenOn 7.10
    I managed to install all the necessary software and configurations based on the manual.
    Unfortunately i'm not able to run zenOn runtime from web client.
    attached here are the screenshot from my computer.
    in Services, Zenon Web is started but port 1102 is not shown in the list from command prompt.
    Default Re: Problem with Web Server on zenOn 7.10
    Hello Misbah,
    Unfortunately there were no screenshots attached to the post, so it is not quite clear from your description what the issue actually is.
    Did you accidentally activate the checkbox "http tunneling"?
    If yes, the zenwebsrv no longer uses port 1102 and operates in a different mode that may sometimes be required when firewalls are used that do deep packet inspection.
    If you don't need the http tunneling, it is recommended to turn off this feature.
    Hello Mark,
    I had the same problem.I have followed all the instructions you provide.
    But when i start the client the error will popup.
    The webserver is already started.
    Runtime server is started as well.
    Please refer attached file if you are not clear.
    Attached Thumbnails Attached Thumbnails clientcount.jpg   init_runtime_error.jpg   Not_found.jpg
    Hi Firdaus,
    Thanks for your post. Judging from your first screenshot I believe this is a different issue than what misbah reported.
    Did you check your webserver to see how many webclients are connected?
    How many clients are licensed in your webserver license, and how many are already running?
    Did you by any chance start the webclient a second time on the same PC? If yes, this message may also appear.
    One issue however has been addressed in the webserver which may apply to you.
    Please see Article ID 126563 in the knowledge base on the service site (you can search the knowledge base for this article ID)
    Hi Mark,
    I found the problem from my PC and I have installed to another PC and it's running like a charm.
    I think the problem is about the connection refuse from the webclient to webserver.
    Because i see an error from event "connection broke down".Maybe you have experienced facing this problem.
    Thanks for your support.
  1. Problem with upgrading the Web-server
    By nurul in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 24th June 2011, 00:01
  2. ZenOn Web Server and VBA?
    By nblanquart in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 28th July 2010, 23:34
  3. Redundant WEB Server
    By okhotnikov in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 9th December 2009, 13:30
  4. Web server
    By rloureiro in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 19th December 2008, 10:24
  5. We need further information about web server on zenOn...
    By nuno_duarte in forum zenon Network
    Last Post: 18th March 2008, 18:05
