Thread: Auto-Login
    29.04.2013
    12
    Default Auto-Login
    Hi, I'd like to implement a swipe card reader into our system. I'd like the operators to login using their own card. I can write the code in VSTA to read the code on the card. Is it possible to automatically login the user using VSTA? If I have a SQL database with login and password for each swipe card, then maybe I can log them in?
    Denis.
    Default Re: Auto-Login
    Hi Denis,
    Yes, there are several possibilities.
    One option assumes that the swipe card reader can be matched to a zenon user that already exists. You can configure a function "login without password" where a string variable of the intern driver set to "local" defines the user name. Then after reading the swipe card reader you can write the string variable with the corresponding user name, and then execute the function to login the user.
    When you have a system (e.g. SQL database) where you can check the validity of the swipe card before logging in the zenon user, you can prevent e.g. login of a user who's swipe card has expired or has been disabled.
    Another option could be to dynamically create a user for each swipe card via the programming interface in VSTA and login that user.
    23.04.2018
    Is it possible to do a "login without password" for a AD user?
    I'm looking to do the same function with a NFC card and the NFC ID is stored in the users AD profile.
    So when i get the ID from the NFC-tag i query the LDAP and get the user this card is registered to and then log that user into Zenon.
  1. Auto Scaling problem
    By zenon in forum VBA
    Last Post: 20th October 2011, 15:06
  2. Auto Logoff
    By yara in forum zenon Supervisor
    Last Post: 31st July 2011, 23:29
  3. Login pichure
    Last Post: 15th December 2010, 23:31
  4. Auto start runtime when windows starts
    Last Post: 12th February 2009, 18:14
  5. Login
    By mrk in forum VBA
    Last Post: 3rd January 2008, 08:44
