Thread: Embedded strings
    29.04.2013
    12
    Default Embedded strings
    Hi, I'm converting a project over to Zenon. I have a combined element with 10 states in it. All the states are text. I'd like to have two of the states have embedded string in them. Is this possible? Example: text for state 4: "Open Door near and press the button ". Both "door_name" and "button_name" wold be strings coming from the PLC.
    (I'm using Zenon 7.10)
    Thanks,
    Denis
    18.07.2011
    138
    Default AW: Embedded strings
    Hi.
    Yes it is possible to have dynamic limit texts. Please check out the zenon help as shown in the screen capture, topic "dynamic limit text"
    There you will further explanations as well as examples how to configure the text to show string values dynamically.
    regards
    29.04.2013
    12
    Default Re: Embedded strings
    I'm not sure how this helps. The help says it's only available for the Alarm Message List and CEL. I'm trying to get it to work in the combined elements. Like "Remove parts %string1, %string2, %string3 from the machine". the strings are built in the PLC and may be up to 82 characters long and have multiple parts indicated in each string.
    Denis.
    880
    With Combi-Elements this is not possible (variables values and also limit text from variables can not be displayed). With Combi-Elements you can display a graphic, symbol from the library, static text, and symbol embedded in screens (see help documentation for more information on this).
    What you can do is to use the "Dynamic text" element. This can show the limit text of the violated variable limit. Or you simply use this element to display the string from the PLC directly.
    regards,
    herbert
  1. Embedded IE version
    By brc in forum VSTA
    Last Post: 1st October 2012, 15:49
  2. webclient und WinXP embedded
    By michab in forum Webserver/Webclient
    Last Post: 29th February 2012, 04:44
  3. Strings compare
    By maro80 in forum zenon Supervisor
    Last Post: 30th October 2008, 18:48
  4. Replies: 1
    Last Post: 13th June 2008, 08:56
