Thread: Reset multiple BOOL tags
    09.05.2013
    52
    Default Reset multiple BOOL tags
    Hi
    I use zenon v7.00 SP0.
    i have the following problem. I have 5 groups of BOOL tags. There are 5 BOOL tags in each group. There names are:
    Group 1
    - PP01_Alm_Alarm1
    - PP01_Alm_Alarm2
    - PP01_Alm_Alarm3
    - PP01_Alm_Alarm4
    - PP01_Alm_Alarm5
    Group 2
    - PP02_Alm_Alarm1
    - PP02_Alm_Alarm2
    - PP02_Alm_Alarm3
    - PP02_Alm_Alarm4
    - PP02_Alm_Alarm5
    etc - you see the idea.
    I want to clear whole 5 tags (in one group) by pressing a button.
    To do that I create 5 functions (Write set value type) each function clears one of the tags - for example PP01_Alm_Alarm1.
    Next I include all 5 function in a script and prepare a function which call the script.
    At the end I configure the function (which call the script) to a button.
    With "Replace links" functionality I thought I could replace tag portion and to do the functionality.
    I was surprised that I can see only the function name of the function calling the script.
    I could not imagine that I have to create full set of functions for each group (these are about 30 functions and 5 scripts)?!?!
    Is there any other solution?
    best regards,
    yolov
    Default Re: Reset multiple BOOL tags
    in this case "Replace indices" would fit better I suppose.
    Check the online help (F1), look out for the following section.
    Manual -> Screens -> Edit screen element -> Replacing linking of variables and functions -> Replacing indexes
    Hi yolovs,
    You could also look at resetting the tags using a standard recipe, or a recipe from the recipe group manager. This way, you would only need one function that can be easily replaced.
  1. Unused tags
    By sdolnyy in forum zenon Supervisor
    Last Post: 19th April 2013, 07:44
  2. Reset of counter variables
    By roberto1978 in forum VBA
    Last Post: 20th June 2011, 10:40
  3. Reset Flashing
    Last Post: 17th May 2011, 00:15
  4. License: Amount of IO <> Tags -- Lizenz: Anzahl IO <> Tags
    Last Post: 5th December 2008, 10:20
