Thread: Screen switch with replace links in multi-server projects
    Default Screen switch with replace links in multi-server projects
    Hello, colleagues!
    I use 6.51
    I have some multi-server system with project A as root-project and project B as child project.
    I have a popup screen where I use replace links to attach its element to neccesary variables.
    If I do this inside one project everithing is OK.
    If I want to show in project A values from project B on this screen, then when I use replacement links like INT.TI -> B#W.TI I get in list of target variables names without B# prefix. So in runtime this window doesn't show values of project B.
    Are replacement links in switch screen functions support multi-server project, and if yes then how?
    Default Re: Screen switch with replace links in multi-server projects
    this feature undergo some concept changes in the past and has been revised fundamentally.
    It works comprehensive and very well now in zenon 7.10.
  1. Replies: 2
    Last Post: 24th May 2013, 04:12
  2. Multi-screen display
    By xaviluci in forum zenon Supervisor
    Last Post: 16th January 2013, 11:12
  3. Screen Switch in VBA
    Last Post: 28th August 2012, 01:26
  4. Multi-log on various projects
    By nblanquart in forum zenon Supervisor
    Last Post: 6th May 2010, 08:24
  5. Picture switch - Replace indices
    By imtech in forum zenon Supervisor
    Last Post: 11th September 2009, 08:35
