Thread: Editing structure datatype
    09.05.2013
    52
    Default Editing structure datatype
    Dear Sirs,
    I need explanations regarding behavior of structure datatype
    I have created structure datatype, named Info, which got only one structured element named "label".
    Next I created to variables of type Info - named G2 and G3.
    Next I add another structure element named "status" to structure type "Info".
    When I look at variable list, "status" was added to G2 and G3, but they was gray. When I select it, nothing appears into properties window.
    in the other way, when I create new variable of type "Info", named G4, the "status" item was presented, and was able to edit its properties.
    I have the following questions:
    - if I change the structure datatype, is there any way to update ALREADY created structure variable?
    - if I change the structure datatype, should I delete all variable of the same datatype, and recreate them again (by the way I copy the G2 & G3 variables in clipboard, edit the structure datatype, past the variable again - this do not solve the problem)?
    - what is the recommended editing procedure when it comes to user-defined structure datatype?
    yolov
    Default Re: Editing structure datatype
    have you checked out the Online Help (F1) regarding Structure Data Types?
    Manual -> Variables -> Datatypes -> Types of data types -> Structure data types
    There you find all around Creating/Changing/Moving and Deleting structure datatypes.
    There you will find some "Attention" boxes which are very important to consider!
    09.05.2013
    52
    Dear Sir,
    Thank you for the update. I looked everywhere but not in the beginning of the variable manual.
    regards,
    yolov
  1. Different drivers in one structure datatype
    Last Post: 13th December 2011, 08:30
  2. Program access to structure datatype variables
    By stolyarov_as in forum VBA
    Last Post: 8th August 2011, 14:21
  3. editing XLM
    By jaroslav.kral in forum zenon Supervisor
    Last Post: 22nd July 2011, 00:09
  4. Editing Pictures in the Master Station
    By rolindo in forum zenon Supervisor
    Last Post: 23rd December 2009, 10:58
  5. How's the alarm status line editing?
    Last Post: 21st November 2009, 05:44
