Thread: Display archived data in table
    09.05.2013
    52
    Default Display archived data in table
    I am using zenon v7.0 SP0.
    How it is possible to display archived analog data in table format?
    Is it possible to define start and end time?
    I have another question!
    How it is possible to display data from SQL database in table?
    I am actually asking which datagrid control I can use. I tried with Microsoft Hierarchical FlexGrid Control, but unfortunately I can not placed it into a screen.
    If I have such grid ny means of ADO and VBA it shouldn't be a problem.
    regards,
    yolov
    Default Re: Display archived data in table
    Hi yolov,
    Both are possible with the optional module "report generator".
    Displaying archived analog data is also possible using the optional module "report viewer".
    When you have evacuated your analog data from a historian into a SQL database through the archive configuration, the report viewer is also able to display this data without any further configuration. The runtime manages the collection of the data (local, from the SQL database, or both) and provides the data to the report viewer module.
  1. Recipe table
    By scadavmesnik in forum zenon Supervisor
    Last Post: 6th August 2012, 23:20
  2. VBA macroses reference table
    By stolyarov_as in forum VBA
    Last Post: 30th October 2011, 23:47
  3. Showing Archived data
    By talal.mubarak in forum zenon Energy Edition
    Last Post: 22nd August 2011, 13:23
  4. Problem with archived trend data
    By k_r_mehta in forum zenon Supervisor
    Last Post: 13th December 2010, 13:23
  5. Language Table Keywords and VBA
    By jhines in forum VBA
    Last Post: 18th September 2008, 14:52
