Showing results 1 to 8 of 8
Thread: Sicam 230
    09.05.2013
    52
    Default Sicam 230
    I am using SICAM 230 in demo mode and I have two questions.
    Why I see very limited number of drivers even I can see the EXE file of the other drivers in SICAM 230 7.00 SP0 installation folder?
    I can not find any Automatic Line Coloring (ALC) functionality in the SICAM 230 editor. Why?
    I am pretty sure that such functionality was available when demo of zenon v7.0 was installed.
    best regards,
    yolov
    09.05.2013
    52
    Default Re: Sicam 230
    I found a solution to the limited list of driver issue!
    What about ACL?
    regards,
    yolov
    josefm Gast
    can you see the information "Automatic Line Coloring" when opening "Help -> About" in the zenon Editor menu?
    (See also screenshot attached)
    If not, talk to your local sales, because then it is not included in your current license.
    09.05.2013
    52
    "Automatic Line Coloring" is missing from the list. I use it in demo mode.
    Obviously this is the case - in not license version it is not available.
    Thanks for help!
    regards,
    yolov
    08.10.2007
    35
    Demo mode means there is no valid activation key.
    In demo mode you do not automatically have all modules available.
    Which modules are available in this demo mode depends on the serial number used.
    Normally, the demo serial number shipped with the product contains all modules.
    14.02.2016
    Hi Gents,
    But anyway how i can solve the issue below? Now i have the same problem with number of drivers.
    Thanks in advance!
    "Why I see very limited number of drivers even I can see the EXE file of the other drivers in SICAM 230 7.00 SP0 installation folder?"
    18.07.2011
    138
    Default AW: Sicam 230
    Dear Vladich.
    Your request is already listed as Support ticket and we will process it via that ticket. We would need the licence number you use and some more confidential Information, therefor we would appreciate if we could investigate this issue via the ticket.
    Thanks for your participation in our Forum though, this is always warmly welcome.
    BR
    13.06.2016
    In my case, I have two demo licenses in SICAM License Tool. Using embedded license i couldn't see AML, but after selecting Load Demo License SRX I can see it.
  1. SICAM 230 with ABB RTU560CMG
    By onder89 in forum zenon Energy Edition
    Last Post: 19th June 2013, 00:20
  2. trying to read system time in plc from sicam
    By imran in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 14th May 2012, 02:28
  3. help in Sicam 230
    By imran in forum zenon Energy Edition
    Last Post: 11th May 2012, 00:11
  4. IEC 61870-5-104 driver for SICAM 230 SP1
    By kirca in forum zenon Energy Edition
    Last Post: 22nd August 2011, 15:04
