Thread: Reset State Bit
    Default Reset State Bit
    I have a variable that has the TIMEOUT State bit set due to the Watchdog timer in the Command functionality. Is there any way to reset this bit manually ?
    Cheers
    Rob
    995
    Default Re: Reset State Bit
    any next succeded command will rest it.
  1. Replies: 2
    Last Post: 29th May 2013, 13:33
  2. Decoding the INT tag bit By Bit
    Last Post: 29th August 2012, 01:29
  3. Reset Flashing
    By tanveerali in forum zenon Service Engine Supervisor
    Last Post: 17th May 2011, 00:15
  4. Rema state
    By westbaaam in forum VBA
    Last Post: 30th November 2009, 06:32
