Thread: VBA doesn`t work in Runtime
    Default VBA doesn`t work in Runtime
    Have a problem with VBA in Zenon 7.0 SP0.
    I have created simple macro in thisProject:
    Public Sub Message ()
    MsgBox "NEW MESSAGE"
    also I made a function to execute this macro.
    But it doesn`t work in runtime. It works fine when I manually start macro in Editor, but not in Runtime. I also tried simple LeftClickUp macro and function "Show VBA macro dialog" - they also don`t work.
    I checked zenon6.ini. Here are the settings:
    [VBA]
    EIN=1
    EVENT=1
    UPDATE=0
    What`s wrong with my project?
    josefm Gast
    Default Re: VBA doesn`t work in Runtime
    here it is working properly.
    Although I thought macros have to start with "Macro" and then whatever you want to name it is not true.
    I attached a screenshot of my macros.
    Have you loaded several projects at the same time? Then I suggest to check in which of the thisProject you created the macros, there is a chance that you have chosen the wrong project file.
    Also a screenshot attached.
    My code:
    Public Sub Test()
        MsgBox "New Message"
    Public Sub Macro_Message()
    Maybe you havent saved and compiled the project ?!
    Please let me know how you proceeded.
    Quote Originally Posted by josefm View Post
    I can't see any principal difference between yours and my code) But I'm sure that I have compiled and saved my project properly. In my workspace is only one project.
    In the attachment is backup of project.
    May this problem occur because of license or something else?
    Regards, Nataliia
    Hi Nataliia,
    Is your runtime license a zenon operator license? In that case VBA is not available.
    Damn, I see. I have zenon operator.
    Thank you for clarifying, Mark.
    Regards, Nataliia
    Default AW: Re: VBA doesn`t work in Runtime
    This is only true for VSTA macros.
  1. Replies: 1
    Last Post: 19th May 2011, 05:54
  2. Replies: 3
    Last Post: 31st March 2011, 09:23
  3. Replies: 5
    Last Post: 14th September 2010, 12:53
  4. Allocation from zenOn to Straton doesn't work?
    By sbc in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 9th February 2009, 13:21
  5. Network doesn't work on Windows CE devices
    Last Post: 28th August 2007, 12:11
