Thread: Display a recources label of the variable
    Default Display a recources label of the variable
    I found that the name or the identification of a variable linked to the combi-element can display with a specific syntax.
    http://www.copadata.com/forums/showt...t=VariableName
    I want to do the same and I want to display a recources label of the variable. What specific syntax I should use?
    Kind regards,
    Dario
    tobiassedlmeier Gast
    Default Re: Display a recources label of the variable
    Hello Dario,
    as I know it is only possible with the Name and the Identification. There is no other Syntax.
    Best regards
    Tobias
    Maybe there is other solution to show a resources label of the variable?
    881
    You can display the resources label via predifnied screen types AML, CEL, ...
    -> check out the column settings in the screen switch functions to those screen types
  1. date and time display using variable
    By paruvathakumar in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 22nd January 2013, 14:58
  2. Display Variable Name
    By knubla in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 30th November 2012, 10:12
  3. Graph display
    By nblanquart in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 18th November 2009, 11:04
  4. Limit Text - Display ID or Name of variable
    By craigdouglas in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th December 2008, 15:23
  5. Display Text Value
    By lengele in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 18th December 2007, 13:50
