Thread: Webclient in IE10 on Windows 7?
    Default Webclient in IE10 on Windows 7?
    Does the webclient work in Internet Explorer 10 on Windows 7?
    Yes, the zenon 7 webclient works in Internet Explorer 10 on Windows 7.
    When using VBA / VSTA on the webclient, the same applies as for older IE versions
    • - the VBA 6.3 setup must be executed from the DVD - Additional Software folder
    • - the VSTA setup must be executed from the DVD - Additional Software Folder (trin_aide.msi)
    • - the settings VBA=1 and EVENT=1 need to be set manually in the file "zenon6.ini" in the %CD_SYSTEM% folder, (hidden folder) using notepad.exe
    • - The checkbox "enable memory protection to mitigate online attacks" needs to be disabled in Internet Explorer in the advanced options under security
      (start IE as an Administrator in order to change the setting, otherwise it may be greyed out)
    Note that disabling the memory protection potentially makes the IE browser less secure. Consider using VSTA in your zenon project as an alternative to VBA, to avoid the need to disable this option.
    14.07.2010
    46
    Default Re: Webclient in IE10 on Windows 7?
    The mentioned checkbox "enable memory protection to mitigate online attacks" is only available on a Windows 7 32 Bit operating system.
    By using Windows 7 64 Bit you have to deactivate that memory protection via using the command line parameter bcdedit.exe/set {current} nx AlwaysOff (see also zenon help of 7.10: zenon Webserver and zenon Webserver Pro -> zenon Webclient -> Browser)
  1. WebClient Screen Configurator
    By herberto in forum zenon Network
    Last Post: 23rd March 2016, 13:17
  2. ScreenSwitch on WebClient
    By ronmany in forum Webserver/Webclient
    Last Post: 26th April 2011, 23:18
  3. Which OS for the zenon webclient?
    By markclemens in forum Webserver/Webclient
    Last Post: 20th March 2010, 18:29
  4. Replies: 0
    Last Post: 31st January 2008, 10:34
  5. VBA on webclient
    By markclemens in forum VBA
    Last Post: 14th September 2007, 08:01
