Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 15
Thread: Report Generator Run Time Text
    30.05.2013
    119
    Default Report Generator Run Time Text
    Hello Everybody...
    I am trying to create a report like RPT-Snap.
    Everything is OK except displaying Month and Year (Highlighted in red color in RPT-Snap).
    Please Help me to obtain the following task,
    Once I select the Month and Year at run time by time filter like TIME_FILTER-Snap, then I have to display the selected Month, Year and Previous Month in Report generator (Like Red Highlighted part in RPT-Snap).
    30.05.2013
    119
    Default Re: Report Generator Run Time Text
    No one answer on this. Is it not possible on Zenon....?
    josefm Gast
    I'm not really familiar with this issue, but can you describe to me, what functions you used and what happens wrong?
    As I see, you select the values of JUNE to display but it shows APRIL and MAY, right?
    Next question: Are the values from the proper month?
    Best regards
    30.05.2013
    119
    No. The reference Snap RPT is made by manually in Excel. I like to create a report as like that by using report generator. I wish to know "How to displaying the name of the selected month after selecting from the time filter...?
    martins Gast
    Default AW: Report Generator Run Time Text
    hi,
    maybe you could use the report function archivetime(filterindex, parameter) for this - because you get the information out of the variables in the archive, so the timestamp would always be correct. You can then format the string with the help of the various string functions (left, mid, replace).
    best regards,
    Martin
    30.05.2013
    119
    Default Re: AW: Report Generator Run Time Text
    Hello Martins,
    I am facing the following problems while I am executing the Report generator function.
    The "Filter" pop-up is not opening to select the month at run time even if I set 1 month in "Set time filter" (Ref:TIME-SETTING.jpg). Report generator is opening directly after pressing the button which is executing the function. But the "Filter" (Ref:FILTER.jpg) pop-up is opening in "Report Viewer" function with the same setting.
    Can you please guide me How to get the "Filter" at run time when I am using report generator?
    I tried to get the Archive time according to your instruction, But there is no option to get like "archivetime(filterindex, parameter)". I am getting Archive time with two options like =archivetime(1,"absolutetimefrom") or =archivetime(1,"absolutetimetill") (Ref:REPORT FUNCTION.jpg).
    Can you please explain me, How did you get Archive time with filterindex?
    Attached Thumbnails Attached Thumbnails TIME-SETTING.jpg   FILTER.jpg   REPORT FUNCTION.jpg
    14.07.2010
    46
    for opening the mentioned pop-up window during runtime you have to enable the Checkbox "Show this Dialog in runtime" -> take a look at the attached screenshot.
    Quote:"Can you please explain me, How did you get Archive time with filterindex? "
    -> the number '1' represents the filterindex.
    Take a look at the zenon help: Manual -> Reporting -> Report Generator -> Engineering in the Editor -> Report functions -> Archive and logging functions -> archivetime
    So your configuration looks correct.
    Daniela.
    30.05.2013
    119
    Thank you Daniela.
    Still I have to check about archive time. Anyway If I have any Query I get back to you.
    A.Navaneet.
    30.05.2013
    119
    Hello Daniela,
    archivetime report function is working ok.
    I am getting the correct time in report generator (Ref:RPT_GEN.jpg) according to my formula [=archivetime(1,"absolutetimefrom") and =archivetime(1,"absolutetimetill") ]. But Is it possible to customize the time according to our requirement? That means Can we display only month like "July" or Month and Year like "July-2013"......?
    Best Regards,
    A.Navaneet.
    14.07.2010
    46
    Lächeln Re: Report Generator Run Time Text
    Yes that is possible.
    As mentioned in the help:"The archivetime function supplies, depending on the time filter that has been set"
    So at the picture switch function to the Report Screen you can define a time filter like one month( see attached screenshot "pictureswitchfunctionreport.png")
    Afterward you get in the runtime while navigating to the Report Screen a pop-up where you can choose the needed month (see screenshot "pictureswitchfunctionreportruntime.png")
    Daniela.
    Attached Thumbnails Attached Thumbnails pictureswitchfunctionreport.png   pictureswitchfunctionreportruntime.png
  1. Alarms in RUN-TIME
    By matteo.fabbri in forum VSTA
    Last Post: 8th March 2014, 17:38
  2. Report Generator
    Last Post: 12th June 2013, 23:34
  3. how to remove windows elements during run time
    By tanveerali in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 25th May 2011, 23:28
  4. Report generator, how to show multiple results at different times in a single report
    By bojan in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
  5. Report Generator
    By rolindo in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 21st November 2009, 23:50
