Thread: Report Generator
    30.05.2013
    119
    Default Report Generator
    Hello Everybody,
    I am trying to make a report generator with Archive datas.
    If I like add the variable directly, there is no problem. But when I am adding variables from Archive, It is allow me to write a "Report function" as "=archive(1,"value","bottom")". This will display the value of first variable which is in selected Archive.
    So if I have 200 variables in one Archive then I want to write 200 "Report function" in different row.
    Is it possible to insert all the variables of one Archive by writing "Report function" once...? Means first variable will be in 1st row and second will be in 2nd row and so on.
    Default Re: Report Generator
    Hi navaneet,
    Yes, this is possible, just make sure that you select the whole archive at the parameter, rather than one specific variable, and that all lines fit into your report
    30.05.2013
    119
    Hi navaneet,
    Hello...
    Please find the snaps for what are all the steps I have followed to add the Archive variables to the report generator cell.
    Please refer STEP-3 and STEP-4 snaps, According to your instruction, I selected the Archive and clicked OK without selecting any variable. Now It is cleared in STEP-6 snap, There is no variable selected because the formula is like as "=archive(0,"value","bottom")". If I follow this step, Nothing is showing in run time.
    But if I select any one of the variable like STEP-7 snap then the formula is also like "=archive(3,"value","bottom")" (STEP-9 snap). I am thinking, Now third variable of the Archive selected. Am I correct...? Now the value is also showing in run time.
    Even I couldn't select more than one variable by pressing "Shift" or "Ctrl" key.
    Can you please guide me now, Where I am doing mistake...?
    How to get all the variables of one Archive by writing single report function in one cell...?
    Attached Thumbnails Attached Thumbnails STEP-1.jpg   STEP-2.jpg   STEP-3.jpg   STEP-4.jpg   STEP-5.jpg
    Hi navaneet,
    I assumed this was possible by using the filter index "0", but after trying this it proves that I was wrong
  1. Zellen verbinden im Report Generator
    By elso in forum zenon Supervisor
    Last Post: 15th June 2012, 01:06
  2. Replies: 9
  3. Report generator
    By sldewit in forum zenon Supervisor
    Last Post: 30th March 2011, 00:11
  4. basic mathematics in report generator
    Last Post: 5th March 2010, 08:40
  5. Report Generator
    By rolindo in forum zenon Supervisor
    Last Post: 21st November 2009, 23:50
