Thread: linking multiple projects
    Default linking multiple projects
    I am facing an unusual error. I have linked three projects together. The issue is when I run the primary project it opens the screen of the third project, rather than opening the screen of the primary project.
    Default Re: linking multiple projects
    Hi tabal.mubarak,
    The attachment only contains one project, so I'm not quite sure what to look at here.
    However I do have a few suggestions when using an integration project:
    - make sure that you use different names of frames in the integration project and the sub projects
    - setup a frame in the integration project that is always in the foreground
    - consider the size and position of the operation frame of the integration project in your sub projects
    I hope this helps
  1. how to combine three different projects
    Last Post: 29th July 2019, 08:13
  2. Logging into multiple projects
    By jurijcadez in forum VBA
    Last Post: 27th November 2012, 15:52
  3. Return to last in 2 projects
    Last Post: 12th March 2012, 00:35
  4. Integrating Projects
    By talal.mubarak in forum zenon Supervisor
    Last Post: 6th September 2011, 23:17
  5. start different projects on CE
    Last Post: 25th September 2007, 08:14
