Thread: mouse event
    24.05.2012
    Augsburg
    30
    Frage mouse event
    Hello Everybody,
    have Problems with following code. The Event does not raise, when i click on a button.
    i have it also testet with other Events like dblClick and so on.. but nothing happens.
    thanks for help.
    Code:
    zenOn.DynPictures zScreens = new zenOn.DynPictures();
    // i also tested with   zenOn.DynPictures zScreens;   without the new statement
    void ThisProject_Active()
        //Create any required API-References here (Event handlers, OnlineContainers, local references,etc. )
        // << TODO: Add Initialization code here >>
        zScreens.ElementLeftButtonUp += new zenOn.ElementLeftButtonUpEventHandler(zScreens_ElementLeftButtonUp);
    void zScreens_ElementLeftButtonUp(zenOn.IDynPicture obDynPicture, zenOn.IElement obElement, int lPosX, int lPosY, int lButton)
        //Do something here
    void ThisProject_Inactive()
        //Release all API-References here (Event handlers, OnlineContainers, local references, etc. )
        // << TODO: Add Clean-up code here >>
        zScreens.ElementLeftButtonUp -= new zenOn.ElementLeftButtonUpEventHandler(zScreens_ElementLeftButtonUp);
        //Final release and garbage collection of any API-Objects.
        FreeObjects();
    Default Re: mouse event
    Hi Armin,
    Judging from your other post, it guess you got it working now
                zScreens = this.DynPictures();
                zScreens = null;
                FreeObjects();
    24.05.2012
    Augsburg
    30
    [IMG]d:\users\armin.seitz\Desktop\mousevent.png[/IMG]
    Hello Mark,
    unfortunately i does not work. There is something missing in my code.
    i send you a picture of my code, hope you can help me.
    24.05.2012
    Augsburg
    30
    Default Mouse Event is not working
    i want to react to a mouse event with the following code, but it doesn´t work. Is the event-routine wrong, or the definition of zScreen ?
    help needed
    Code:
           int count = 0;
     // zScreens = this.DynPictures();
                FreeObjects();
            #region Macros (Add macros in this region)
               count++;
               this.Variables().Item("Testvar1").set_Value(0, count);
    Hi Armin,
    I moved your post to your existing thread.
    Use "zenOn.IDynPictures zScreens;" instead of "zenOn.DynPictures zScreens;"
    and use "zScreens = this.DynPictures();" in project active.
    Also make sure to remove the event handler in project inactive, and release the references.
    best regards,
    24.05.2012
    Augsburg
    30
    Lächeln AW: Re: mouse event
    Hi Armin,
    best regards,
    Thank you, appreciate it
  1. Problem with mouse click
    Last Post: 8th November 2012, 14:25
  2. Mouse over
    By croc in forum VBA
    Last Post: 23rd December 2011, 13:25
  3. Mouse wheel and world view
    By gz0000 in forum zenon Supervisor
    Last Post: 3rd February 2011, 09:32
  4. Touchscreen operation: deactivation of mouse cursor
    By herberto in forum zenon Operator
    Last Post: 7th May 2010, 09:18
  5. Drawn event
    By flajoso in forum VBA
    Last Post: 26th August 2008, 11:09
