Thread: Zenon 7 registration error with "ZenDbSrv is running" message
    Default Zenon 7 registration error with "ZenDbSrv is running" message
    Hello, support team!
    I try to switch into 7.00 SP 0 Build 5 on my windows 7 32 bit from 6.51 SP 0 Build 14 using Startup Tool.
    During this process I get error window (see attachment), then Startup Tool finished its work.
    How to start 7.00?
    josefm Gast
    Default Re: Zenon 7 registration error with "ZenDbSrv is running" message
    have you changed the settings in the zenDB.ini?
    Or anything in the properties of the database settings like in the screenshot attached?
    Usually the settings in the properties of the startup tool are mandatory, so please check these settings because it seems that the zenDBsrv cannot start and this can be caused by wrong connection settings.
    Best regards
    Unfortunately i didn't change zenDB.ini file.
    Moreover I copied zenDB.ini file from another computer where zenon 7 start OK with no result.
    Any other suggetions? As I understand Diagnostic Viewer is not appliable for startup tool diagnostic.
    May be I can try to repeat Startup Tool actions manually?
    Default AW: Zenon 7 registration error with "ZenDbSrv is running" message
    can you check the file version of your zenAdminSrv.exe (C:\Program Files\Common Files\COPA-DATA\zenAdminSrv)
    Default Re: AW: Zenon 7 registration error with "ZenDbSrv is running" message
    zeAdminSrv file version is 7.0.0.705 last changed 11.12.2012
    I think I found solution - Reason was in my antivirus update.
    After antivirus disable everithing is OK. Thanks for your help.
  1. Zenon 6.51sp0 Microsoft Visual Basic "System error &H80040111"
    By iop_p in forum Engineering Studio & Service Engine
    Last Post: 27th March 2013, 22:40
  2. Replies: 0
    Last Post: 23rd March 2010, 04:16
  3. I always get "Error # -60 Opening file" with the function "Read Dbase file
  4. "prepare this blank disc" message when inserting 6.22 DVD
    By markclemens in forum Engineering Studio & Service Engine
    Last Post: 21st February 2008, 13:43
  5. Replies: 0
    Last Post: 18th September 2007, 14:12
