Thread: web server stopping
    29.02.2008
    40
    Default web server stopping
    For unknown reason the my Web server stoppes by itself from time to time.
    - What could be the reason?
    - Is it possible to show in Run time the status of web server (started/stopped, number of clients)
    - is it possible to create a function to automatically restart the web server if it stopps?
    Thanks and best regards!
    Jurij.
    Default AW: web server stopping
    usually this should not happen.
    If the Webserver runs in Demo mode it stopps after 30 minutes.
    Which version are you using?
    Can you check the Logfile or with the DiagViewer (depending on the version) if there are any errors?
  1. Problem with upgrading the Web-server
    By nurul in forum Webserver/Webclient
    Last Post: 24th June 2011, 00:01
  2. ZenOn Web Server and VBA?
    By nblanquart in forum Webserver/Webclient
    Last Post: 28th July 2010, 23:34
  3. Redundant WEB Server
    By okhotnikov in forum Webserver/Webclient
    Last Post: 9th December 2009, 13:30
  4. Web Server Functionality
    By tauhien in forum Webserver/Webclient
    Last Post: 16th September 2009, 08:06
  5. Web server
    By rloureiro in forum Webserver/Webclient
    Last Post: 19th December 2008, 10:24
