Thread: Free memory (%) variable - for what kind of memory?
    Default Free memory (%) variable - for what kind of memory?
    Hello, support team!
    Now we playing with Hardware resources variables of SYSDRV driver.
    Free memory (KB) value is equal with windows task manager physical memory available value in MB - we have not any question about it.
    Free memory (%) is much greather then 100% - task manager physical memory available value in %.
    So question is - what value shows this variable (Free memory (%))? Does it include virtual memory available?
    Default Re: Free memory (%) variable - for what kind of memory?
    Hi stolyarov_as,
    Could you provide some more Information on your environment?
    - which Windows Version are you using?
    - which Windows Edition are you using? (32 bit or 64 bit)
    - which zenon Version are you using?
    - when using zenon 7.10, which runtime (32 bit or 64 bit) are you using?
    - how much RAM does the System have installed?
    Hi markclemens.
    I checked this on both 6.51 Build14 and 7.00 Build5.
    I use Windows 7 32bit.
    And my PC has 4 GB of RAM.
    1 490 000 value Free memory (KB) was in same time as 71 value of Free memory (%) (windows system monitor shows 55%)
    1 000 000 KB was in same time as 48% (windows system monitor shows 71%)
    640 000 KB was in same time as 30% (windows system monitor shows 82%)
    I can only suppose that 100% is about 2GB but not understand why.
    Default AW: Free memory (%) variable - for what kind of memory?
    i did some tests/research and came to the following conclusion:
    zenon shows 69% free - Windows shows 30% used -> OK
    Available memory is the same in zenon and Windows -> OK
    See here for the description of available/free memory:
    http://brandonlive.com/2010/02/21/me...-in-windows-7/
    Can you check this with your configuration?
    Hi bernhardf,
    In attachment there are my detailed test/research.
    And I'm still not understand why V460 shows such % values.
    It looks like you calculate % as sum of cashed+available+free divided to 4192 MB of total phisical memory of 4GB (instead of 3,5GB available Total memory shown on process monitor screenshots).
  1. Replies: 6
    Last Post: 20th March 2015, 09:03
  2. InitInstance():Out of memory
    Last Post: 4th April 2012, 23:58
  3. Memory Leak when using IArchiveFilter.Query()
    By stolyarov_as in forum VSTA
    Last Post: 13th September 2011, 13:02
  4. CEL Entries from memory or file
    By roberto1978 in forum zenon Supervisor
    Last Post: 8th February 2010, 11:57
  5. memory on windows CE
    Last Post: 19th September 2007, 08:05
