Thread: Alarm Dynamic Limit
    30.05.2013
    119
    Default Alarm Dynamic Limit
    Hello...
    If I like to use the dynamic limits for Numerical value, there is one option available like "Dynamic limit active" with one internal variable. But for example, if I have 1000 numerical value and each variable is having 4 limits then, I need to create 4000 (1000*4) internal variables. This is very lengthy procedure.
    Please let me know, Is it any other option available for this Dynamic limit...?
    Navaneet.
    Default AW: Alarm Dynamic Limit
    are these dynamic limits all independent from each other?
    Because if not you could use the same "dynamic limit" variable for different variables.
    If you really need 4000 variables, you could use VBA/VSTA to create and link multiple variables in a short time (e.g in a loop, there are VBA samples in the manual).
    Default Re: Alarm Dynamic Limit
    Some other suggestions that may be helpful:
    regarding creating variables with VBA / VSTA: take a look at the variable creation wizard. This will help you quickly create a large number of variables.
    Alternatively, you could also create an Array of internal variables with 4000 entries. Or you could create a user defined structure datatype, with an Array of 4 items, and create an Array of 1000 items based on this user defined structure type.
    In regard to your numerical variables, you can create a user defined numerical datatype, that already has 4 dynamic Limits predefined. Then base your numerical values with the dynamic Limit, on this type.
    What you could also do is look at the .csv Export / .csv Import, and e.g. edit your variables / Limits in Microsoft Excel, if you are more familiar with that than e.g. VBA or VSTA
    30.05.2013
    119
    Yes. Variables are having different limits.
    I know Array of variable, importing and exporting of variable in .csv etc. I like to know, Is it possible to change the limits by using one pop-up with only four internal variables...?
    Thank you for your information.
    Default AW: Re: Alarm Dynamic Limit
    Quote Originally Posted by navaneet View Post
    Could you be a little more specific on that, e.g. with a practical example?
    Are the limits still dynamic? - How should it work with only 4 internal variables for the dynamic if each limit is different for the 4000 variables?
    30.05.2013
    119
    Default Re: AW: Re: Alarm Dynamic Limit
    When we click on the numerical value, it will open the pop-up window.
    There is an option available to write the values (write set values by element) to our internal variables for limits, After writing those values click the "accept" button. It will execute some scripts and write the values to exact variable limits on the actual clicked variable.
    Is it possible like that...?
    Otherwise there is no problem to create the internal tags for limits, it is the straight method and simple also.
    Thank you for your great help.
  1. Dynamic Limit Text and string variable value
    Last Post: 22nd March 2013, 09:19
  2. Replies: 2
    Last Post: 16th August 2012, 14:19
  3. Why Dynamic Limit Text allows only 1 variable?
    By batabaha in forum zenon Supervisor
    Last Post: 1st May 2012, 23:51
  4. Dynamic limit texts in structure datatypes
    By lew in forum zenon Supervisor
    Last Post: 9th January 2012, 00:50
  5. Dynamic limit texts with hexadecimal value
    Last Post: 9th January 2012, 00:41
