Thread: read variable from runtime
    24.05.2012
    Augsburg
    30
    Unglücklich read variable from runtime
    i am a beginner with zenon and have Problems with reading a variable from the runtime.
    public void Macro1
    int x=0;
    zenOn.IVariable yVar = this.Variables().Item("testvar1_2");
    x = (int)yVar.get_Value(0); <------does not work , x is always 0
    but it does not work. The x Value is always 0
    Default AW: read variable from runtime
    is the variable you want to read "advised" (visible in a screen, in an online container, defined as an alarm, set to DDE active", ...)
    If not, you won't be able to read a value until the variable is advised.
    Have also look at:
    http://www.copadata.com/forums/showthread.php?t=1129
    http://www.copadata.com/forums/showthread.php?t=1074
    http://www.copadata.com/forums/showthread.php?t=1542
    24.05.2012
    Augsburg
    30
    Default Re: read variable from runtime
    Thanks.... it works
    i did it like this, whithout any adivising. I hope this is a good way.
    public void Macro1()
    float x = 0;
    x = Convert.ToSingle(this.Variables().Item("PLCVar1").get_Value("PLCVar1"));
    this.Variables().Item("PLCVar2").set_Value(0,x);
    Default AW: Re: read variable from runtime
    Quote Originally Posted by armins View Post
    Thanks.... it works
    float x = 0;
    If this code works, the problem was most likely with the casting of the value.
    Nevertheless, besides this the value has to be advised to be readable in VSTA.
    (Which is the case if it is shown in a screen at the time being read for example).
    24.05.2012
    Augsburg
    30
    Lächeln Re: AW: Re: read variable from runtime
    Quote Originally Posted by bernhardf View Post
    Thank you Bernhard.
  1. VSTA read variable value's another project!
    By dvangenderen in forum VSTA
    Last Post: 1st December 2011, 10:04
  2. Replies: 2
    Last Post: 22nd September 2011, 01:32
  3. Variable Unreadable in runtime
    By whitetaru in forum Drivers
    Last Post: 12th May 2011, 03:23
  4. Replies: 12
  5. Replies: 4
    Last Post: 21st June 2010, 07:12
