Thread: Straton in multi servers system
    Default Straton in multi servers system
    Hello colleagues
    Can you help me?
    I use multi servers system. A main HMI server don't have a straton program. Two slave HMI servers use a same straton program.
    When the main HMI server started one of straton projects on the slave HMI servers began work incorrectly and I got error message, see the attachments.
    What can be a reason?
    I already tried to change names of straton logic program and port numbers. But still get this message. I get this message even if I have empty one of straton project.
    25.06.2012
    156
    Default Re: Straton in multi servers system
    Hello altera,
    Did you already read this thread?
    DC
    Hello david.cerdeira
    Thank you very much.
    Now I read topic from your link. And I could solve my problem.
    When I changed a port number for straton runtime logic I also found property "Start place".
    I set this property from "all computers" to "Server" and my straton projects now work correctly on both HMI servers.
  1. Multi-Monitor with different resolutions
    By martijnvanspijk in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 22nd May 2013, 12:26
  2. Multi-screen display
    By xaviluci in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 16th January 2013, 11:12
  3. something wrong in use between multi version?
    By zhangbb_dimension in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 15th May 2012, 05:21
  4. Multi-log on various projects
    By nblanquart in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th May 2010, 08:24
