Thread: Increase/decrease value
    09.04.2013
    57
    Default Increase/decrease value
    how to increase/decrease current value (for i.e. 1) in Zenon?
    Regards.
    Default Re: Increase/decrease value
    Hi Tihomir,
    There are several possibilities. Which one is best depends on what you are after exactly.
    You can for example create a send value to Hardware function, set the option "suggest current value", and define the value for set value to "1". Each time the function is executed, the value of the variable will incremented by 1.
    Is this what you were looking for?
    09.04.2013
    57
    Hi Mark,
    thanks for reply.
    Do you mean Write set value function?
    I dont see "suggest current value" option?
    I need function for decreament REAL value also.
    Regards.
    Hi Tihomir,
    Yes, "write set value". (in older Versions the function was once called "send value to hardware")
    Please have a look at the screenshot:
    09.04.2013
    57
    I dont know what to say, except...thank you Mark.
    You are really helping me.
    Best regards.
