Thread: reaction matrix
    06.04.2013
    8
    Default reaction matrix
    I hope you can help me in the following problem too:
    I created a binary reaction matrix with two state with different function:
    1: Calls Function1 (Screen switch function to my alarm screen)
    0: Calls Function0 (Screen: return to last)
    And my "AlarmExists" boolean variable is using this reaction matrix. (PLC writes this variable)
    When I have alarms then AlarmExists = true.
    When I start RT I get the following error: Back is not possible as there is no screen path yet. I would like to stop getting this message when I start RT.
    In the project properties there is a Execute limit functions at RT start option. It is not good for me to unchecked it because if AlarmExists = true at RT starting then the screen switch doesn't happen.
    Could you suggest something to solve my problem?
    Thanks,
    Peter
    Default Re: reaction matrix
    Hi Peter,
    Have a look at the multi-binary reaction Matrix. Instead of executing the "Screen return to last" function on value "0", you can use a multi-binary reaction Matrix to execute this function on a falling edge (value changes from "1" to "0")
    06.04.2013
    8
    Hi Mark,
    Thanks for your suggestion, it solved my problem.
    Peter
  1. Report. Reaction matrix
    By natali in forum zenon Supervisor
    Last Post: 27th November 2012, 12:23
  2. Reaction Matrix
    By archie in forum zenon Energy Edition
    Last Post: 24th May 2012, 18:26
  3. Replies: 1
    Last Post: 30th August 2011, 14:32
  4. Reaction matrix ?
    Last Post: 5th August 2009, 01:05
  5. Reaction Matrix
    Last Post: 1st May 2008, 16:02
