Thread: Disable double right click acknowledge
    06.04.2013
    8
    Default Disable double right click acknowledge
    It doesn't take long for me to require some help again.
    Is it possible to disable double right click to acknowledge alarms on alarm status line and alarm message list?
    Thanks,
    Peter
    Default Re: Disable double right click acknowledge
    Quote Originally Posted by robolution View Post
    Hi Peter,
    You can set an authorization level for acknowledging alarms, and use the user Administration to prevent users from acknowledging alarms.
    Check out the "function authorization" in the "Project properties" - section "user Administration"
    Is that of any help?
    Another idea may be to look at the "comment required" option for alarms that was introduced with zenon 7.00. An alarm cannot be acknowledged before a comment is entered. (the comment field could e.g. only be visible to certain users)
    Ausrufezeichen Re: Disable double right click acknowledge
    Dear Support,
    I have tried this, However, double tap over alarm on Alarm Screen still get acknowledges alarms. The authorization only disable the Ack button available on side in same Screen.
    My customer does not want Comments on alarms
    Can you help in suggesting the alternate method of disabling double tap Acknowledging of alarms ?
    I am using 7.11 build 12493 in my project.
    Regards
    Dauji Varshney
  1. Disable grid lines in trend XY
    By galax in forum zenon Supervisor
    Last Post: 3rd April 2013, 09:42
  2. Flash Acknowledge
    By talal.mubarak in forum zenon Supervisor
    Last Post: 13th July 2012, 00:51
  3. Right Click issue
    By whitetaru in forum VBA
    Last Post: 26th April 2011, 06:46
  4. There is a way to disable monitor assign function
    Last Post: 25th October 2009, 07:40
  5. How to disable click sounds on virtual keyboard
    By balzse in forum zenon Operator
    Last Post: 8th October 2008, 09:06
