Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 20
Thread: Zenon runtime security warning
    29.02.2008
    40
    Default Zenon runtime security warning
    I installed all W7 updates and installed the Zenon 7.1, imported the workspace backup.
    In my project I use Web Cameras. In Z6.51 it worked ok. In new Z7.1 I get the following error (see atached document). I have played with different settings in Internet explorer but was not able to fix the problem. The system is blocking index.cgi installation from remote Web camera. It seems that this is originated in Zenon, cause I can view the IP cameras in explorer.
    Any idea how can I fix this problem?
    Best regards!
    Jurij.
    josefm Gast
    Default Re: Zenon runtime security warning
    Hi Jurij,
    have you tried to deactivate the Microsoft Windows Firewall and to add it in the Microsoft Internet Explorer to the trusted sites?
    On the bottom it says "To help protect your computer, Windows will block Software when it cannot verify the Publisher.", so maybe since updating Windows 7 some system configurations may have changed and are causing this error.
    Best regards
    You can try and add the URL for the IP cameras to the "trusted sites" in the Internet Explorer Options, perhaps that will help
    29.02.2008
    40
    Hello!
    I have allready done the "trusted sites" and disabling the firewall, but this does not helk. Funy thing is that in windows explorer I am able to run the index.cgi and view the cameras. But in Zenon I get the arror message.
    I am open for any new ideas.
    Best regards!
    Jurij.
    josefm Gast
    Hi Jurij,
    just an idea, but have you also installed the Internet Explorer 10 update on Windows 7?
    As far as I know there are differences (by Microsoft) by handling everything so you could try different versions there.
    Best regards
    29.02.2008
    40
    Hello!
    I did an update of windows, but here is IE9 installed. I will install IE10 today and try again.
    Thanks and best regards!
    Jurij.
    24.07.2008
    88
    Default AW: Re: Zenon runtime security warning
    Quote Originally Posted by jurijcadez View Post
    Hello!
    Jurij.
    Hi Jurij,
    I found a discussion on a Microsoft forum about a similar issue:
    http://answers.microsoft.com/en-us/i...3-afcb5a3f2e36
    If you think you have a misconfiguration in your IE, you could try to reset all Internet Explorer settings to their defaults -> Internet Options -> Advanced -> Reset.
    Hope this helps!
    Konstantin
    29.02.2008
    40
    I did installation IE10 and reset IE settings.
    No improvement.
    BR,
    Jurij.
    Hi Jurij,
    Are you using a 64 bit Version of Windows? If yes, do you have this issue in 7.10 both with the 32 bit and the 64 bit zenon runtime?
    29.02.2008
    40
    Hi Mark,
    you are wright.
    The problem is only in 64 bit runtime. 32 bit runtime works OK.
    BR,
    Jurij.
  1. Zenon Runtime / Terminal Server
    By kfn3000 in forum zenon Network
    Last Post: 23rd December 2015, 17:30
  2. Opening a folder in zenon runtime
    By talal.mubarak in forum zenon Supervisor
    Last Post: 7th October 2014, 16:03
  3. Zenon 6.51 vs Windows CE licensed in runtime in Zenon7.0
    By rbfernandez in forum zenon Operator
    Last Post: 24th September 2012, 13:43
  4. Zenon 6.50 Sp0 build 1 warning
    Last Post: 11th August 2010, 08:19
  5. Displaying .xml data in zenon Runtime
    Last Post: 2nd March 2010, 02:34
