Thread: Change variable status
    30.11.2007
    13
    Böse Change variable status
    Please, how to change variable status to alternate value, seting alternate value and seting back tu spontanous value ???
    Thanks Miro.
    robertf Gast
    Blinzeln Re: Change variable status
    The Variable Status can be changed with the RecipeGroupManager or VBA.
    Here is an Example how to change the status to Alternatevalue: Alternate Value - ON/OFF
    Public Sub Change2Alternate()
    Dim zVAR As Variable
        Set zVAR = thisProject.Variables.Item("WIZ_VAR_10")
        Debug.Print zVAR.StatusString
        zVAR.StatusString = "EWERT=1"
    Public Sub Change2Spontaneous()
        zVAR.StatusString = "EWERT=0"
    With this Code the Status of the variable will be changed, but the variable will not switch to the alternate value!
    If you post some more information about your exactly needs, I may help you better...
    30.11.2007
    13
    Lächeln Re: Change variable status
    Thank you.
    My customer want to setting process signal if this signal is wrong (Hand setting).
    robertf Gast
    Default Re: Change variable status
    Does the given VBA Code help you?
    If not please explain what is going wrong!
    I do not exactly understand what you want to do...
    30.11.2007
    13
    Your answer is better. Thanks.
    30.11.2007
    13
    Please, how to change value of alternate value ??
    Brada.
  1. Value, Time-Stamp and status with allocations
    Last Post: 14th September 2007, 07:57
  2. Replies: 0
    Last Post: 21st August 2007, 08:15
