Thread: PROFIBUS commands
    19.02.2013
    2
    Default PROFIBUS commands
    does anyone have experience with PROFIBUS commands?
    How to make pulse commands for PROFIBUS?(example)
    Thank you in advance.
    Default Re: PROFIBUS commands
    Hi jroht,
    Welcome to the Forum!
    Could you please elaborate on what you mean with PROFIBUS commands? Or with the pulse command for PROFIBUS?
    mark
    19.02.2013
    2
    Hi mark,
    this is my first PROFIBUS project and I not familiar with PROFIBUS.
    I must establish connection between SICAM 230(7.00 SP0) and SICAM SAS RTU (based on the SIMATIC S7/M7-400 automation system). I use PROFIBUS driver S7_NT. States, signals and measuring starts work, but commands not. I used functions "write set value". I think that I am using the wrong command structure. Maybe must use some special script or logic.
    Another problem is I cannot import S7 project. Screenshot is added.
    809
    Typically the 'write set value' function is the right way. But maybe the RTU expects something special, is it possible to check the RTU's manual?
    For problem with import of S7 project i propose you to contact your Support; hard to say without access to this project.
  2. DNP commands
    By ansab.tp in forum zenon Energy Edition
    Last Post: 28th September 2012, 11:31
  3. Straton with Profibus and Simatic I/O
    By karnst in forum straton / zenon Logic
    Last Post: 2nd August 2012, 12:32
  4. Siprotec-Profibus DP
    By marchelo in forum Drivers
    Last Post: 18th July 2010, 20:20
  5. Commands interlockings Problem
    Last Post: 24th August 2009, 00:59
