Thread: Unused tags
    01.11.2012
    60
    Default Unused tags
    HIi Guys,
    please advise how to sort out which tags are not used in the project?
    I am faced with the issue that one customer site is having license for 1024 tags and other just for 512. My screens are far enought to stay with 512 but I have many tags imported as the project variables for future development.
    How to sort this out and remove from the project unseded ones. The editor license is for unlimited ammount of tags. Zenon 6.51 SP0, build 0
    Thank you.
    Kind regards,
    Sergiy
    25.06.2012
    156
    Default Re: Unused tags
    Hello sdolnyy,
    In zenon 6.51 you can use Cross reference list at zenon Options > Cross reference list main menu.
    Simply select one module and follow the attached capture1.jpg picture until you reach Unused variables. Select it and you will get a list of the variables you are searching for.
    Hint: Don't forget to always backup before execute any change in project and to test it before going to a real environment.
    DC
    01.11.2012
    60
    Super!
    Thank you, David. I will try it now.
    Kind regards,
    Sergiy
    08.10.2007
    35
    please always try first to search if already some Threads available which could may answer your question. Concerning this issue I found some see the following list!
    Check them out as you might get some more information details!
    Thread1
    Thread2
    Thread3
    Thread4
    01.11.2012
    60
    Quote Originally Posted by compu2000 View Post
    Thank you. I did a search for "unused tags" "used tags" and was not so lucky to find that topics you are pointing to.
    Kind regards,
    Sergiy
  1. Hardware-Bedarf für Projekt mit 10.000 tags?
    By michab in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 17th March 2013, 23:33
  2. Can zenon handle 800,000-word-tags?
    By sunnamkung in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th March 2012, 23:22
  3. Import Step7 tags
    By scotttee in forum Drivers
    Last Post: 22nd April 2009, 19:33
  4. License: Amount of IO <> Tags -- Lizenz: Anzahl IO <> Tags
    By herberto in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 5th December 2008, 10:20
  5. Improving communications speed high number on tags on CE Runtime
    By mattsd in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 20th February 2008, 10:23
