Thread: CEL Filter
    15.04.2013
    7
    Default CEL Filter
    I have observed that there is an entry with text "modify spontaneous value"(please refer the attachment) in the chronological event list for few variables when the value is changed. I have neither created any reaction matrix nor configured any limit for this particular entry in CEL. Can you please suggest how i can remove this entry in the CEL?
    Default Re: CEL Filter
    kavya,
    In Write set value section of variables properties you should clear Setting values with VBA flag.
    15.04.2013
    7
    I cleared the Setting values with VBA flag as suggested (please refer screen shot). But i am still getting two events for the same bit in CEL. I want logging for only the event i have configured and not the "modify spontaneous value". Could you please advise how to remove this log in CEl?
    1,023
    It writes in CEL each time when you enter new value using some dynamic sreen element. Exactly like is set in the option 'Logging' on your screenshot. Change 'Only via dynamic element' to 'Nothing'.
    15.04.2013
    7
    It is working now, thank you.
  1. CEL and AML filter restricitons
    By stolyarov_as in forum zenon Service Engine Supervisor
    Last Post: 22nd January 2013, 06:30
  2. CEL issue when use ? symbol in filter
    Last Post: 16th April 2012, 11:05
  3. Filter Cel results in certain intervals
    By bojan in forum zenon Service Engine Supervisor
    Last Post: 29th March 2011, 23:54
  4. CEL/AML User Filter definiert im Runtime
    By jusufs in forum zenon Energy Edition
    Last Post: 23rd February 2011, 12:57
  5. CEL Filter
    By hicom in forum zenon Service Engine Supervisor
    Last Post: 24th August 2010, 11:51
