Thread: Zenon v7.0 OPC Server Version
    Default Zenon v7.0 OPC Server Version
    I would like to know which DA Version(s) does Zenon OPC Server Support ?
    DJ
    Default Re: Zenon v7.0 OPC Server Version
    Hi DJ,
    Welcome to the forum
    There are two OPC server available for zenon. An OPC DA 2.0 server supporting asynchronous communication and an advanced OPC UA server.
    Ausrufezeichen Re: Zenon v7.0 OPC Server Version
    Hi Mark..
    Thanks for the Warm Welcome & Support.
    Please Correct me if I am Wrong, the Version is same for the Process GTW OPC DA Sever also.
    Right !!
    DJ
    Hi DJ,
    Yes, sorry for the misunderstanding. The zenon OPC DA 2.0 server and the zenon process gateway OPC server are the same thing.
    Thanks Mark for the Quick Reply...
    Regards
    DJ
  1. Zenon OPC Server Versions and Compliances?
    Last Post: 15th June 2013, 01:39
  2. Zenon OPC Server Issue
    By shikra in forum Drivers
    Last Post: 29th May 2012, 01:31
  3. Opc Server
    By tanveerali in forum Drivers
    Last Post: 18th January 2012, 00:01
  4. OPC-server Kepware and Zenon 6.51
    By croc in forum Drivers
    Last Post: 13th August 2011, 01:44
  5. Advantage of ZenOn Energy version versus Standard version?
    Last Post: 23rd June 2011, 23:54
