Thread: Disable grid lines in trend XY
    27.03.2013
    19
    Default Disable grid lines in trend XY
    I have to make some trends XY using zenOn 6.22 SP1 Build4.
    Unfortunately, in addition to the graph; displays a horizontal line that represents the value taken from the memory (I enclose sample image).
    I noticed that the color of this line is related to the color of the grid, but I could not eliminate it altogether.
    it is possible to disable the reference lines in question?
    Sincerely,
    Alessandro.
    Default Re: Disable grid lines in trend XY
    Hi Allesandro,
    Welcome to the forum!
    I think I know what you mean with the reference lines. The only thing I can think of at the moment, is to set the color of the grid lines the same as the color of the background of the chart. I assume the option "display horizontal gridlines" is disabled at all of the curves?
    Maybe someone else here has another Idea?
    27.03.2013
    19
    Thanks for your reply Marck.
    The "grid lines" (see attached picture) is disabled.
    I also thought I had to make the color of the lines of the same color of the background.
    Unfortunately, the grid lines are drawn above the chart causing the cancellation (visivile effect also in the first message attached picture)
    If I can not disable the lines then I think it will be better to make them visible :-)
    Sincerely,
    Alessandro.
  1. Multi monitor in grid 2x2
    By brada in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 25th October 2011, 09:05
  2. Trend und Erweiterter Trend
    By lutzmayr in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 18th October 2011, 15:03
  3. T-Junction of Lines fed by two Sources (ALC)
    Last Post: 15th April 2010, 00:35
  4. There is a way to disable monitor assign function
    By shahramkh59 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 25th October 2009, 07:40
  5. How to disable click sounds on virtual keyboard
    By balzse in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 8th October 2008, 09:06
