Thread: Own DLL Library/Matlab/Complex controller structure Integration with the Zenon
    06.12.2012
    6
    Default Own DLL Library/Matlab/Complex controller structure Integration with the Zenon
    Hey Guys,
    I want to process plant data collected by Zenon by a controller and then send it back via Zenon to the plant. What is the best way to implement quite complex structures like Kalman filters, Model Predictivre Control in Zenon? Is it possible to integrate my own DLL libraries with Zenon? Or maybe I can integrate Matlab/Simulink models with the Zenon?
    Default Re: Own DLL Library/Matlab/Complex controller structure Integration with the Zenon
    Hi pwlodar,
    Welcome to the forum
    There are a few possibilities. The zenon logic is a IEC61131 logic that allows a large number of calculations to be performed with full access to the variable values in the zenon runtime. The zenon logic also allows integration of user defined c function blocks.
    zenon also allows integration of Dlls through the programming interface. By using VSTA. you could take the value changes received in the zenon runtime, call a function in the dll that performs the calculation, and write the result back to a zenon variable.
    03.12.2013
    Hi everyone,
    Can anybody tell me how exaclty access those DLL's from VSTA? Since it doesn't have a possibility to create a DLL file, I don't have a clue how to import them.
    08.08.2013
    44
    Hi sejton,
    you can include dll-files in the following way:
    1. open VSTA Editor
    2. make a right click on "ProjectAddin" and select "Add Reference" in the Context Menu
    3. click on the tab "Browse" and select the dll-file
    BR
    Christian
  1. zenon 7 Microsoft Visual C++ Runtime Library Error
    By alin.stoicovici in forum Editor and Runtime Setup
    Last Post: 20th November 2012, 09:29
  2. Replies: 1
    Last Post: 19th May 2011, 07:51
  3. integration project
    By aurel in forum zenon Supervisor
    Last Post: 9th January 2011, 23:20
  4. Replies: 0
    Last Post: 4th March 2009, 09:50
  5. Replies: 9
