Hello colleagues
I am using v7.00 build5 now and found some problems in zenon Logic.
I set Externally visible property for variables that use these variables in zenon Logic. But if I have changed variable name in zenon in Logic the name of variable don't change until I uncheck and check again Externally visible property.
Another problem.
It's not possible edit variables as text in zenon Logic. I always got error, look at the attachment file.
If you select "as csv format" in this window all data will be lose.
