Thread: Screen Timer
    Default Screen Timer
    Hi All,
    How do I create an on-screen timer that will count down from 90 seconds?
    Cheers,
    Rob
    25.06.2012
    155
    Default Re: Screen Timer
    Hello Rob,
    You can create a zenon Logic project where you use a Down Counter function block.
    Please, let me know if you need more information how to set this.
    DC
    Hi David,
    I've never used zenon Logic before, so if you could provide some more information on how to do this that would be great !
    Cheers,
    Rob
    25.06.2012
    155
    Ok
    What is your zenon version?
    If you are using zenon 7.00 I attached a sample project where you can see all the configurations done in zenon workspace and in zenon logic workbench.
    You can read more information about the Counter Down FB if you select it and then press f1 in zenon Logic workbench.
    For more information about zenon Logic I refer you to documentation: manual > zenon Logic. There you can find all the basic information you need.
    hint: Be aware that the executing cycle timing must be set to 1000ms to set one second steps.
    Tell me if you have any doubts after checking carefully the project.
    Please consider this only a sample project. Must not be use in real environment systems.
    DC
    Hi David,
    This is just what I needed and works fine. Thanks for your help.
    Rob
  1. Close one screen, opens other screen
    Last Post: 14th November 2012, 10:34
  2. Timer for control
    By yara in forum Drivers
    Last Post: 28th January 2011, 14:32
  3. Wrong behaviour for timer/VBA
    By matholton in forum VBA
    Last Post: 1st November 2009, 15:58
  4. VBA Timer
    By hansvanzijp in forum VBA
    Last Post: 15th September 2009, 03:04
  5. Replies: 0
    Last Post: 18th September 2008, 13:07
