Thread: Process gateway(Modbus)
    Default Process gateway(Modbus)
    in process gateway of zenon(7.0), i have noticed that there is only option for setting holding register offset. But i want to configure for read input register in process gateway(function 02h). How do i make this possible?
    879
    Default Re: Process gateway(Modbus)
    please check the help documentation on this:
    Manual -> Process Gateway -> Requirements
    Attention
    If the Modbus Slave driver is used, the Process Gateway only supports:
    Function Code 3: Read Multiple Registers
    Function Code 16: Write Multiple Registers
    regards,
    herbert
  1. Process Data Gateway
    By knubla in forum Drivers
    Last Post: 30th January 2013, 10:47
  2. Process Gateway
    By murphys in forum Drivers
  3. DNP- Process Gateway
  4. Process gateway-DNP3
    By rolindo in forum Drivers
  5. Process Gateway
