How is it possible to positioning the form exactly over the element?
The "problem" in this case is that VBA does not use pixel units. It uses the so-called "twips".
The procedure is as followed:
1. get the actual position of the the cursor
2. calculate the the pixel postion into twips units
3. check if the position of the form exeeds the limits of the screen
4. handover the new positioning information to the form
The code below has to be inserted in the LeftClickUp-Event
Name of the LeftClickUp-Event: LeftClickUp_PosOverElement
Name of the UserForm: frmToTest
The code should work for different screen resolutions.
Option Explicit
Private Type RECT
    Left As Long
    Top As Long
    Right As Long
    Bottom As Long
End Type
Private Type POINTAPI
    x As Long
    y As Long
End Type
Private Declare Function GetCursorPos Lib "user32" (lpPoint As POINTAPI) As Long
Private Const SPI_GETWORKAREA& = 48
Private Declare Function SystemParametersInfo Lib "user32" _
      Alias "SystemParametersInfoA" _
    (ByVal uAction As Long, _
      ByVal uParam As Long, _
      lpvParam As Any, _
      ByVal fuWinIni As Long) As Long
Private Declare Function GetDC Lib "user32" (ByVal hwnd As Long) As Long
Private Declare Function ReleaseDC Lib "user32" (ByVal hwnd As Long, ByVal hdc As Long) As Long
Private Declare Function GetDeviceCaps Lib "gdi32" (ByVal hdc As Long, ByVal nIndex As Long) As Long
Private Const HWND_DESKTOP As Long = 0
Private Const LOGPIXELSX As Long = 88
Private Const LOGPIXELSY As Long = 90
Public Sub LeftClickUp_PosOverElement(obelem As Element)
    Dim pTargetPoint As POINTAPI
    Dim lRetVal As Long
    Dim rc As RECT
    lRetVal = GetCursorPos(pTargetPoint)
    Call SystemParametersInfo(SPI_GETWORKAREA, 0&, rc, 0&)
    'positioning of the form ****
    frmToTest.Top = ((rc.Top + pTargetPoint.y) * TwipsPerPixelY / 20) - frmToTest.Height / 2
    frmToTest.Left = ((rc.Left + pTargetPoint.x) * TwipsPerPixelX / 20) - frmToTest.Width / 2
    'check top border
    If (((rc.Top + pTargetPoint.y) * TwipsPerPixelY / 20) - frmToTest.Height / 2) < 0 Then
        frmToTest.Top = 0
    End If
    'check bottom border
    If (rc.Top + pTargetPoint.y + frmToTest.Height / 2) > rc.Bottom Then
        frmToTest.Top = rc.Bottom * TwipsPerPixelY / 20 - frmToTest.Height
    End If
    'check left border
    If (((rc.Left + pTargetPoint.x) * TwipsPerPixelX / 20) - frmToTest.Width / 2) < 0 Then
        frmToTest.Left = 0
    End If
    'check right border
    If (rc.Left + pTargetPoint.x + frmToTest.Width / 2) > rc.Right Then
        frmToTest.Left = rc.Right * TwipsPerPixelX / 20 - frmToTest.Width
    End If
    frmToTest.Init obelem       'hand over all properties to the procedure "Init"
    obelem.LeftClickUp          'release the button
Function TwipsPerPixelX() As Single
  Dim lngDC As Long
  lngDC = GetDC(HWND_DESKTOP)
  TwipsPerPixelX = 1440 / GetDeviceCaps(lngDC, LOGPIXELSX)
  ReleaseDC HWND_DESKTOP, lngDC
End Function
Function TwipsPerPixelY() As Single
  Dim lngDC As Long
  TwipsPerPixelY = 1440 / GetDeviceCaps(lngDC, LOGPIXELSY)
End Function
Below you can find the code to positioning the form at the corners or in the center.
Replace the code above at the position " 'positioning of the form ****"
'BottomRight:
'BottomLeft:
    frmToTest.Left = rc.Left * TwipsPerPixelX / 20 '- frmToTest.Width
'TopRight:
    frmToTest.Top = rc.Top * TwipsPerPixelY / 20 ' frmToTest.Height
'TopLeft:
    frmToTest.Top = rc.Top * TwipsPerPixelY / 20 '- frmToTest.Height
'Center:
    frmToTest.Top = (rc.Bottom / 2) * TwipsPerPixelY / 20 - frmToTest.Height / 2
    frmToTest.Left = (rc.Right / 2) * TwipsPerPixelX / 20 - frmToTest.Width / 2
