Page 1 of 3 1 2 3 LastLast
Showing results 1 to 10 of 21
Thread: Edit variable in Editor from VBA
    23.11.2012
    33
    Default Edit variable in Editor from VBA
    Hello!
    Help me, please!
    How do I edit variable in Editor from VBA?
    18.07.2011
    138
    Default AW: Edit variable in Editor from VBA
    Hi Natali.
    Please have a look into our help. In Manual -> Programming interface -> Object model -> Variable / Variables you will find an explanation of the objects as well as example code. I'm pretty sure that you will find the functionality you are looking for in the example code.
    Sub CreateVariable()
    Dim zVariables As Variables 'Object from type Variables
    Dim zVariable As Variable 'Child object from type Variables
    Dim zDrivers As Drivers 'Object from type Drivers
    Dim zVarTypes As VarTypes 'Object from type VarTypes
    Dim zEdLimit As EdLimit 'Object from type EdLimit
    'Fill the objects
    Set zVariables = MyWorkspace.ActiveDocument.Variables
    Set zDrivers = MyWorkspace.ActiveDocument.Drivers
    Set zVarTypes = MyWorkspace.ActiveDocument.VarTypes
    'Create a "intern driver" variable called "TestVariable" with object type "internal variable" and datatype "INT"
    Set zVariable = zVariables.CreateVar("TestVariable", zDrivers.Item(0), 33, zVarTypes.Item("INT"))
    'Create a limit at the "TestVariable"
    zVariable.CreateEdLimit
    'Select the first limit of the variable
    Set zEdLimit = zVariable.EDLimitItem(0)
    'Set the limit active
    zEdLimit.Active = True
    'Set limit text
    zEdLimit.Text = "Limit reached"
    'Set limit value to 10
    zEdLimit.LimitValue = 10
    'Set the limit as maximum
    zEdLimit.IsMax = True
    'Set the limit as alarm
    zEdLimit.Alarm = True
    'Limit should be recognized in the CEL
    zEdLimit.Cel = True
    Call CreateArrayVariable
    Sub CreateArrayVariable()
    Dim zArrEl As Variable 'Object from type Variables
    Dim i As Integer
    'Fill the objects
    'Create a "intern driver" array variable called "ArrayVar" from object type "internal variable", datatype "INT", start at index 1,
    'dimension of 5 and automatic addressing
    Set zVariable = zVariables.CreateArrayVar("ArrayVar", zDrivers.Item(0), 33, zVarTypes.Item("INT"), 1, 5, 0, 0, True, False, False)
    'Activate all array elements
    For i = 0 To 4
        zVariable.ActivateSubItem (i)
    Next i
    'Read the first array element
    Set zArrEl = zVariable.SubItem(0)
    'Create a limit at the array element
    zArrEl.CreateEdLimit
    Set zEdLimit = zArrEl.EDLimitItem(0)
    'Set limit text
    zEdLimit.Cel = True
    23.11.2012
    33
    Default Re: AW: Edit variable in Editor from VBA
    Thank you.
    I saw it. But I have a error in "Set zVariables = MyWorkspace.ActiveDocument.Variables"
    run-time error '91':
    Object variable or With block variable not set
    Default Re: Edit variable in Editor from VBA
    what exactly do you want to do?
    Are you executing this code in the Runtime?
    23.11.2012
    33
    Quote Originally Posted by bernhardf View Post
    Yes, in Runtime!
    I want change TagName.
    Thank you.
    josefm Gast
    as far as I know you cannot change the TagName during runtime. This is only possible in the editor for the manipulation of variables.
    Best regards
    23.11.2012
    33
    Quote Originally Posted by josefm View Post
    Best regards
    If this is true, it is very sad
    18.07.2011
    138
    You can check if a object is changeable in the runtime using the zenon help. If it says "available" the object can be read and changed. If it says "read only" you cannot change it. Attached you will find the screenshot of the zenon help for the variable tagname, as you see it can only be read from the runtime.
    23.11.2012
    33
    Quote Originally Posted by johannes.foidl View Post
    Thank you. I get it!
    But can you explain to me how to correct the error 91?
    I have seen many posts where people use code like
    mguid = MyWorkspace.ActiveDocument.Guid
    without problems
    Maybe I need to make any adjustments in the project?
    880
    for doing stuff in the zenon Editor via VBA you have to insert you VBA Code at ZWorkspace. Either you put your code their into "MyWorkspace" or you define a own module within ZWorkspace.
    For VBA Code which should be executed in the zenon Runtime of a project you put the VBA Code into "ZYourProjectName" -> "thisProject"
    VBA of the zenon Editor and zenon Runtime (Project) are seperated.
    regards,
    herbert
  1. .arx archive edit
    By bastien in forum zenon Supervisor
    Last Post: 13th June 2012, 15:06
  2. Replies: 0
    Last Post: 11th March 2010, 15:59
  3. Edit Variable limit (Delay)
    By rloureiro in forum VBA
    Last Post: 12th September 2008, 09:25
  4. Replies: 0
