Thread: Camera image in browser window
    gandi Gast
    Default Camera image in browser window
    Hi.
    I have a questrion about html screen. I want to create the screen (or element, what would be even better) which only shows the direct image from my ip camera. The drivers are not found with Video screen, so my next idea was to search for html. And it works - there is an access to camera. But what I'd like is disabling the possibility to change the url. I want browser window to display the view under IP and nothing more. Is it even possible? Where does the input in Address Element go to? Is there any variable responsible of that?
    Thanks for help.
    Default Re: Camera image in browser window
    if you remove all control element beside the "Browser Window" from the screen you should have no possibilty to navigate, see:
  1. Camera Feeds
    Last Post: 5th February 2014, 15:50
  2. Button Graphics Image
    By conradsmith in forum VBA
    Last Post: 14th January 2013, 23:37
  3. How does Firefox work as a Web-Client Browser?
    By lephis in forum Webserver/Webclient
    Last Post: 24th June 2009, 20:07
  4. VBscript under window CE
    By stephanepilon in forum zenon Operator
    Last Post: 16th May 2008, 15:26
  5. "variable image remanent" setting is not saved
