Thread: VBA and Microsoft Access
    bjoerndavid Gast
    Default VBA and Microsoft Access
    I need to transfer data from a Access table to certain tags in Zenon. How can I do this in VBA?
    880
    Default Re: VBA and Microsoft Access
    Do you want to do this via MSAccess VBA or from zenOn VBA?
    Due to zenOn provides a VBA interface for external applications realizing this from MSAccess VBA should be not a big deal.
    Btw: which zenOn version / MSAccess version do you use?
    Looking forward for your answer.
    bjoerndavid Gast
    Hello Herbert
    Thank you for responding. I have almost solved the problem. I have got the the VBA-code in Zenon from a friend. I use the Zenon Ver 6.2 and Access 2002. Export the table in access to a txt-file and read with a VBA in Zenon. But I still have a problem with exporting from Access. There is a macro-fasility for sending data in access with txt-options, but this does not generate the right data-structure in the txt-file. Export the datatable manually makes the right structure in the exported file. You might have a tip?
    Regards Bjørn David
