Thread: Execute a Function on changes of a Float Variable
    09.10.2011
    9
    Default Execute a Function on changes of a Float Variable
    I use Zenon 6.51 version and want to ask a question. I try to execute a function on every change of a float variable. The variable is read from a SQL Server with SQL-Driver and its update time is nearly 15 minutes.
    Can you help,
    With Best regards,
    27.06.2011
    96
    Default AW: Execute a Function on changes of a Float Variable
    Hello mcavdar,
    you can do this with a reaction matrix.
    In the ReMa you need to add a condition with value "any" and "treat eauch change of the value as new limit violation".
    Then you can add the required function in the ReMa and link the ReMa to the variable in question.
    best,
    Alex
    09.10.2011
    9
    Default Re: Execute a Function on changes of a Float Variable
    Thank you alexf..
  1. How to trigger a function when a variable changed?
    By denver in forum zenon Supervisor
    Last Post: 16th May 2012, 10:12
  2. Execute function in VBA
    By focus in forum VBA
    Last Post: 17th January 2012, 15:17
  3. Replies: 1
  4. Replies: 1
  5. Execute VBA macro
    By captain in forum VBA
    Last Post: 24th November 2009, 23:58
