Thread: Zenon Editor 6.20 - Control Logic Addressing
    12.11.2012
    Default Zenon Editor 6.20 - Control Logic Addressing
    I just recently started using Zenon Editor to edit Krones HMI screens. I've figured out how to link a variable address from the editor to a Siemens PLC but, Im having trouble linking to a control logic PLC. I know the driver needs to be LOGIX32 LOGIX32, but the Addressing is confusing. One of the fields is labelled Data block, but data blocks are non-existent in Control Logic. Any help would be appreciated.
    Daren
    Default Re: Zenon Editor 6.20 - Control Logic Addressing
    Hi Daren,
    With the control logix PLC, the addressing is name based, unlike the siemens PLCs which require a numerical data block and a numerical memory offset.
    The logix32 driver supports online browsing of variables from the PLC, which are then automatically created in the zenon editor. (only select the variables you need to make sure you don't exceed your licensed tag count)
    Have a look at the driver documentation for the logix32 driver, which should be located on your zenon DVD!
  1. Can not restore a *.prj file from the zenOn Explorer with the zenOn Editor
    By kyle_lee in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
  2. IOA addressing issue with IEC60870-5 104 driver in zenOn
    Last Post: 28th January 2016, 10:57
  3. ActiveX Control in zenOn
    By sebastiank in forum VBA
    Last Post: 27th February 2009, 19:38
  4. Replies: 0
