Thread: Comma as separator for decimal value
    Default Comma as separator for decimal value
    Hello
    I need to use a comma as separator for decimal value in Report. I created report by Report Generator. I found in help what it's possible.
    Info
    The following applies in runtime: A decimal value can be entered with a comma as well as with a period as a separator. It is always displayed as a period.
    But I coldn't find where I have to change this property in project.
    Can you help me? I use v6.51 build14.
    1,066
    Default Re: Comma as separator for decimal value
    I do not have any good news for you
    When in the zenon Help it is written that the decimal places are always displayed separated with the '.'
    - even when you typed comma - then it means that it is not a setting you could change. It is not a property of the project, it is the fix way how the Report Generator works.
    Manual -> Reporting -> Report Generator -> Operating during Runtime:
    A period is used as a decimal separator. When inputting, either a period or a comma can be used. The separator is then automatically converted by the system to a period.
    Example: 10,5 is turned into 10.5
    So it means that by entering numbers you can type on keyboard comma or dot, but on display you will always see dot.
    Thank you for the information.
    It's not a good news for our customers
    05.05.2014
    Kocaeli/Turkey
    15
    Hi Everybody...
    I woıuld like to be informed about events, if there are any developments in problem...???
    11.01.2016
    We also have projects here in Slovenia, where localization is a main requirement.
    So zenon should use international settings set in Windows Control Pannel like every other modern software today.
    Please inform me if there will be any progress on that issue. Thank you.
    Igor Gruden
    Exor Eti, d.o.o., Slovenia
