Thread: Zenon 6.51 license vs. Demo mode
    15.09.2012
    10
    Default Zenon 6.51 license vs. Demo mode
    Hello
    I have some trouble in uploading the HMI program created in Zenon 6.51(license editor + runtime) to the Windows CE 6.0 Brodersen RTU32. I have already installed the Remote Runtime Update for version 6.51.0.
    Whenever I established remote connection and input the serial and activation number which we purchased(zenon runtime 6.51 version) it says "Compatibility: 'Not Guaranteed' - Please make sure the that the Runtime files are created for a matching version !" .So when I continue uploading the HMI program and run remotely it starts in DEMO mode.
    I notice the remote version when I established connection is 7.0.0.The same version when I run remote runtime update. Is this the correct version or it should be 6.51?
    Can you give us some help?
    Ron
    josefm Gast
    Default Re: Zenon 6.51 license vs. Demo mode
    Dear Ron,
    have you already checked the file version of the zenonRCE.exe in your COPA-DATA\CE\ folder ?
    Are you also using 7.00 in house? The question now it, if you're using 6.51 editor and runtime how could it happen, that the zenon 7.00 runtime is on the device.
    If you have a license for zenon CE 6.51 you should also transfer the runtime files via the UpdateCE tool from the version 6.51 editor. If you don't have zenon CE installed for 6.51 you should be able to download it on the homepage or contact the sales responsible.
    Best regards
    15.09.2012
    10
    hello.
    I have Zenon 7.0 editor and runtime before but downgraded to 6.51 because of long time response issue.
    I have Zenon 6.51 editor and runtime plus the WIndows Update CE for 6.51. I used to tranfer runtime files using this Update CE.
    You are correct the version is different. ”SysSrvCE.exe” is different version installed on RTU. The Flash card and the files insde on it came from brodersen is version 7.0.I just replace the files with version 6.51.
    Thank you for support
    Ron
  1. Process Gateway module in demo license
    By michael_k in forum Gateways
    Last Post: 4th July 2017, 13:35
  2. How to transfer a Zenon license?
    By willetin in forum zenon Service Engine Supervisor
    Last Post: 19th January 2011, 11:08
  3. Zenon 5.50 SP5 Demo Version Needed
    By adf_kdm in forum Engineering Studio & Service Engine
    Last Post: 20th August 2010, 08:07
  4. Zenon License
    By rolindo in forum zenon Service Engine Supervisor
    Last Post: 10th November 2009, 22:27
  5. WebServer starts in Demo-Mode at OS-Start although proper license is available
    By herberto in forum Smart Server & Smart Client (former Webserver & Webclient)
