Thread: Shared memory online variables management
    07.10.2009
    5
    Default Shared memory online variables management
    I've developed a gateway in C# to manage online variables through shared memory for reading and writing a lot of variables.
    It works with great performance compared the normal online variables in bulk mode expecial it's great in writing speed!
    But I have just one problem the string size in the shared struct you have defined is fixed to 64 byte:
    1. Is it possible to change this number (for string length) through some secret parameter in some secret place like zenon6.ini for example?
    2. If in ZenOn editor I declare a variable whith more character and in runtime from zenOn element I write a long string there's no control when you write in shared memory and you override the next struct in the memory. I think It's best cut the string in the shared to the maximum allowed from the struct.
    This is your struct:
    BYTE bFlags; // Bit0=von zenOn geändert, Bit1=extern
    // geändert
    DWORD dwStatus; // Statuswort bitcodiert (gestört, Hand, etc.)
    DWORD dwTimestamp; // Zeitstempel in s seit 1.1.1970 00:00 GMT
    union
    BYTE bBool; // numerischer Rohwert (0=FALSE, 0xFF=TRUE)
    BYTE bByte; // numerischer Rohwert INT_8 oder UINT_8
    WORD wWord; // numerischer Rohwert INT_16 oder UINT_16
    DWORD dwDWord; // numerischer Rohwert INT_32 oder UINT_32
    float fFloat; // numerischer Rohwert IEEE single
    double dDouble; // numerischer Rohwert IEEE double
    double dNumerical; // numerischer Wert normiert
    char csString[64]; // alphanumerischer Wert
    } Value;
    Matteo
    martins Gast
    Default Re: Shared memory online variables management
    Quote Originally Posted by matteo.fabbri View Post
    hi,
    to the first question: no, the definition of the struct is done hardcoded in the zenon source code.
    to your second point: best solution will be to check this by the length of the string. As the struct always has this size and as you are operating in the memory itself, there is no check like you know it from the .NET Framework - that is the downside of the data exchange over shared memory you have to handle that yourself.
    best regards,
    Martin
  1. straton-zenon shared variable
    By batabaha in forum straton / zenon Logic
    Last Post: 13th April 2012, 00:14
  2. InitInstance():Out of memory
    Last Post: 4th April 2012, 23:58
  3. Replies: 4
    Last Post: 22nd February 2012, 20:42
  4. Replies: 0
    Last Post: 19th September 2007, 11:06
  5. memory on windows CE
    Last Post: 19th September 2007, 08:05
