Thread: zenon 7 Microsoft Visual C++ Runtime Library Error
    alin.stoicovici Gast
    Default zenon 7 Microsoft Visual C++ Runtime Library Error
    Hello I have the following problem: I get the "Microsoft Visual C++ Runtime Library Error" when installing zenon 7. I had zenon 7 installed and it worked fine until I got this error. I tried reinstalling and now I get the same error.
    Do you have any suggestions to what I can do?
    Thank you in advance.
    josefm Gast
    Default Re: zenon 7 Microsoft Visual C++ Runtime Library Error
    Hi alin,
    which build are you using ?
    have you tried to re-register the zenon version in the startup tool ?
    have you changed any settings in the zendb.ini or changed settings in the tab "database" in the startup tool ?
    regards
    Than you for your help!
    Reregistering worked for me.
    Alin Stoicovici.
    By douglasm in forum VSTA
  2. Error message from Microsoft Visual Basic
    By robcha in forum Editor and Runtime Setup
    Last Post: 5th November 2012, 07:33
  3. Replies: 1
    Last Post: 28th April 2011, 23:37
  4. Runtime Error
    Last Post: 10th April 2011, 16:25
  5. Replies: 0
    Last Post: 4th March 2009, 09:50
