Thread: Close one screen, opens other screen
    Default Close one screen, opens other screen
    I want to create a button which closes opened screen and opens other screen by one click. What function I should use?
    Dario
    27.06.2011
    96
    Default AW: Close one screen, opens other screen
    Hello Dario,
    there are various ways for realizing this.
    First of all, if both screens sue the same Frame, thereŽs no need to close the screen. It will be closed automatically.
    If they use different frames you could create a script with two functions - close screen and switch to screen. The button would then have to execute the script.
    Another way would be to add the close screen function to the start function of the other screen (youŽll find this in the screenŽs properties). With this solution the button could just execute the screenswitch function.
    hope this helps,
    cheers,
    Alex
    02.07.2010
    13
    Default Re: Close one screen, opens other screen
    Hi Dario,
    You can create a script. Scripts are used to execute several functions. Link a function which executes a script to a button and you can start several functions with one click.
    Anton
    Default Re: AW: Close one screen, opens other screen
    Thanks a lot. It works great with a script.
    Dario
  1. C# form on screen
    By brc in forum VSTA
    Last Post: 4th July 2014, 11:58
  2. Multi-screen display
    By xaviluci in forum zenon Supervisor
    Last Post: 16th January 2013, 11:12
  3. Screen resolution
    Last Post: 16th May 2008, 15:49
  4. screen template
    Last Post: 24th April 2008, 08:00
