Thread: Calling VSTA Macro
    06.11.2012
    16
    Default Calling VSTA Macro
    I've added a simple VSTA macro which displays a message
    public void TestButton()
    MessageBox.Show("This is a test.");
    When I create a function to Execute VSTA macro the Macro Selection pop up is empty. I built ths project by going to build > BildProjectAddin and still nothing appears. Does anyone have any idea how to call the macro? Thank you.
    06.11.2012
    16
    Default Re: Calling VSTA Macro
    I just found out by changing the macro name from TestButton to Macro1 it now shows up in the list of available macors.
    29.07.2007
    Germany
    192
    Default AW: Calling VSTA Macro
    Hello!
    found this case running into the same problem...
    In the help it is mentioned that a function that you would like to call in editor or runtime have to start with Macro...
    Any idea why there is such a rule? Using VBA there is no rule like this?
    Here ist the part of the help, sorry it is in german:
    Achtung
    Die Methodennamen dürfen ausschließlich mit Macro (beispielsweise Macro1, MacroVSTA) beginnen, keine Parameter beinhalten und müssen als Public definiert sein. Zudem dürfen der Klassenname und andere von VSTA erstellte Methoden und Events nicht verändert werden
    H.-P.
    this is a technical restriction and it has to be named with the prefix "Macro" for filtering issues.
  1. Replies: 5
    Last Post: 4th December 2014, 09:45
  2. VSTA Macro c# - Funktion "VSTA_Makro ausführen"
    By ilia_romeikov in forum VSTA
    Last Post: 17th September 2012, 13:44
  3. Replies: 2
    Last Post: 6th March 2012, 11:09
  4. Error in VSTA Macro(get_Value)
    By focus in forum VSTA
    Last Post: 16th February 2012, 13:58
  5. VSTA macro with arguments
    By sldewit in forum VSTA
    Last Post: 28th September 2010, 12:10
